소개
If the bass in your Sonos Playbase is weak or distorted, the subwoofer may be failing or non-functional. This guide shows you how to remove and replace the subwoofer.
필요한 것
이 단계에 사용된 도구:Pro Tech Toolkit$74.95
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
다른 한 분이 해당 안내서를 완성하였습니다.
