소개
This guide will provide you with a detailed process on how to replace the back case of a Sony a6000 camera. Prior to replacing the case, make sure to remove the battery. Steps 1-4 will guide you on how to take out the battery and steps 5-12 guide you on how to replace the back case. The recommended tools for this procedure are a screwdriver, opening tools, a magnetic project mat, and gloves.
필요한 것
Position the camera with the bottom facing upwards and the lens facing away from you.
Slide the notched locking bar on the battery compartment from LOCK to OPEN.
다른 2명이 해당 안내서를 완성하였습니다.
