주요 콘텐츠로 건너뛰기
Sony α6000 Back Case Replacement
필요한 것
  1. Sony α6000 Back Case Replacement, Battery: 1 단계, 이미지 1/2 Sony α6000 Back Case Replacement, Battery: 1 단계, 이미지 2/2
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Back Case Replacement: 2 단계, 이미지 1/2 Sony α6000 Back Case Replacement: 2 단계, 이미지 2/2
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Back Case Replacement: 3 단계, 이미지 1/2 Sony α6000 Back Case Replacement: 3 단계, 이미지 2/2
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Back Case Replacement: 4 단계, 이미지 1/2 Sony α6000 Back Case Replacement: 4 단계, 이미지 2/2
    • Remove the battery.
  5. Sony α6000 Back Case Replacement, Back Case: 5 단계, 이미지 1/1
    • Position the camera with the bottom facing upwards and the lens facing away from you.
  6. Sony α6000 Back Case Replacement: 6 단계, 이미지 1/1
    • Once the battery is removed, use a Phillips #00 screwdriver to remove the three screws at the bottom of the battery compartment.
  7. Sony α6000 Back Case Replacement: 7 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the screws located next to the camera strap.
    • There may be screws on either side by the camera strap mounts. If removing the screw on the left side doesn't sufficiently loosen the case, be sure to check for a screw on the other side before resorting to excessive force.
  8. Sony α6000 Back Case Replacement: 8 단계, 이미지 1/2 Sony α6000 Back Case Replacement: 8 단계, 이미지 2/2
    • Position the camera with the battery housing facing upwards.
    • Remove the two screws on the bottom of the camera using the Phillips #00 screwdriver.
  9. Sony α6000 Back Case Replacement: 9 단계, 이미지 1/1
    • Position the camera with the flash assembly facing upwards.
    • Remove the screw located underneath with a Phillips #00 screwdriver.
  10. Sony α6000 Back Case Replacement: 10 단계, 이미지 1/2 Sony α6000 Back Case Replacement: 10 단계, 이미지 2/2
    • Pull back the LCD screen.
    • Remove the three screws directly underneath using the Phillips #00 screwdriver.
  11. Sony α6000 Back Case Replacement: 11 단계, 이미지 1/1
    • Gently pop off the top case of the camera using your fingers or a plastic opening tool.
    • If using a plastic opening tool, ensure that the pressure is being applied to the plastic rather than the metal.
  12. Sony α6000 Back Case Replacement: 12 단계, 이미지 1/2 Sony α6000 Back Case Replacement: 12 단계, 이미지 2/2
    • Position the camera with the LCD screen facing upwards.
    • Gently remove the back case guiding it around the LCD screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 70
전체 시간: 1,587
