주요 콘텐츠로 건너뛰기
Sony α6000 LCD Screen Replacement
필요한 것
  1. Sony α6000 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Remove the two 1.75mm Phillips #00 screws located on the bottom border of the LCD screen.
  2. Sony α6000 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Remove the two 1.75mm Phillips #00 screws located on the back side of the LCD screen.
  3. Sony α6000 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Carefully separate the bottom border of the frame from the back surface of the LCD screen.
  4. Sony α6000 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Remove the silver shield from the back side of the LCD screen.
  5. Sony α6000 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Remove the smaller bracket covering the bottom portion of the control board.
  6. Sony α6000 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Carefully remove the spacer from behind the LCD screen.
  7. Sony α6000 LCD Screen Replacement: 7 단계, 이미지 1/1
    • Detach the ribbon from the socket with a pair of tweezers.
  8. Sony α6000 LCD Screen Replacement: 8 단계, 이미지 1/1
    • Pull the LCD screen away from the camera and set aside.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rohn Albertson
회원 가입일: 07/14/19
635 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G2, Harley Summer 2019 IUPUI, Team S2-G2, Harley Summer 2019 회원
IUPUI-HARLEY-SU19S2G2
3 회원들
안내서 5개 작성하였습니다
댓글 2개
Step 2 makes this repair impossible, the LCD screen is stuck at an angle where it's impossible to get a normal Phillips onto it without stripping the screw. Horribly inaccurate picture of how 'easy' it is to put the screwdriver there. Don't follow this guide.
Rawr Peng - 답글
Saw a bran new a6000 screen on eBay. So, I thought it would be easy to replace the scratched screen from my a6000. WOW was I wrong!
First I would say that step 2 is very hard to accomplish without stripping the screw. You need to pry the screen to get to an angle where it's doable. On my first attempt I striped the screw. I tried it on a second a6000 and successfully could remove the screw.
As it wasn't evident to me at first, I think it's important to specify that on step 7 you need to lift carefully the little black flap on the zero insertion force cable connector to unlock it. It's weak and I feel like it would be very prone to breaking.
What is NOT showed on this guide is what comes AFTER step 8! The screen is actually in a plastic frame That does not ship with the replacement screen and this frame is glued! So unless you have plastic glue and are able to unglue it first, you should NOT attempt this repair.
Consequently, I reassembled everything and have resigned myself to living with the scratchs.
Drgonz0 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 47
30일 전: 188
전체 시간: 4,498
