주요 콘텐츠로 건너뛰기
소개
Sometimes batteries die. In this guide, we will show you how to replace the battery in the Sony Action Cam HDR-AS15. This is a relatively simple guide, not requiring the removal of any screws.
부품
지정된 부품이 없습니다.
  1. To access the battery, push left on the rear cover of the action cam. The rear panel should easily slide to the side.
    • To access the battery, push left on the rear cover of the action cam. The rear panel should easily slide to the side.
  2. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  3. Open the rear panel outward to reveal the battery tray and memory card slot.
    • Open the rear panel outward to reveal the battery tray and memory card slot.
    • Pinch the protruding bar next to the "Pull" text and slide the tray outwards.
  4. When the battery tray has been removed from the Action Cam, you can simply pull the battery out of the tray.
    • When the battery tray has been removed from the Action Cam, you can simply pull the battery out of the tray.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Justin Calean
회원 가입일: 2015년 01월 09일
414 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-2, Sullivan Winter 2015 USF Tampa, Team 1-2, Sullivan Winter 2015 회원
USFT-SULLIVAN-W15S1G2
4 회원들
안내서 6개 작성하였습니다
Im trying to find thr battery tray i cant find one anywhere at all
focused200m - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 1,017
