이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Sometimes batteries die. In this guide, we will show you how to replace the battery in the Sony Action Cam HDR-AS15. This is a relatively simple guide, not requiring the removal of any screws.
필요한 것
To access the battery, push left on the rear cover of the action cam. The rear panel should easily slide to the side.
Open the rear panel outward to reveal the battery tray and memory card slot.
Pinch the protruding bar next to the "Pull" text and slide the tray outwards.
When the battery tray has been removed from the Action Cam, you can simply pull the battery out of the tray.
다른 2명이 해당 안내서를 완성하였습니다.
