이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
To access the battery, gently pry open the rear cover of the action cam.
이 단계에 사용된 도구:Tweezers$4.99-
Using a pair of tweezers, firmly grip the protrusion where the PULL signifies and remove the tray and battery.
Open the bottom tab with your finger or a plastic opening tool.
Pull the tab out, not up, to remove it completely.
Remove the two screws from the device.
Use your fingers to remove the plastic plate.
Separate the outer casing from the electronics by pushing on one of the ports toward the back end of the case. The electronics should slide right out.
Remove the two 6.4 mm screws on the LCD side of the device using a Phillips #00 screwdriver.
Flip the LCD display downward to reveal the circuit board.
Remove the pieces of black tape holding in the speaker. Put them aside for re-assembly.
Pry the speaker out from its slot gently, careful not to rip the wires from the circuit board.
A ribbon cable attaches the LCD to the circuit board, this can be removed by gently pulling on the cable as close to the end that attaches to the circuit board as possible.
Gently remove the metal piece by pulling out to the right on the upper right corner first, and then on the bottom left corner.
Two clips hold in the LCD screen. Bend these back slightly with a plastic tool or with your hands while pushing on the front of the LCD screen so that the clips do not snap back into place
After the clips have been undone, use the plastic opening tools to pry out the LCD screen.
다른 한 분이 해당 안내서를 완성하였습니다.
