주요 콘텐츠로 건너뛰기
Sony Action Cam HDR-AS15 Memory Card Replacement
  1. Sony Action Cam HDR-AS15 Memory Card Replacement, Getting to the Memory Card: 1 단계, 이미지 1/1
    • To access the memory card, push left on the rear of the Action Cam. The rear panel should easily slide to the side.
  2. Sony Action Cam HDR-AS15 Memory Card Replacement, Removing the card: 2 단계, 이미지 1/1
    • After sliding the rear panel to the side, open the door outward to reveal the memory card slot and battery tray.
    • Push in on the back of the memory card with the tip of your finger until you feel a click.
    • Pinch the rear of the memory card that is protruding from the slot and pull on it until the memory card is removed.
결론
Justin Calean
회원 가입일: 01/09/15
421 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-2, Sullivan Winter 2015 USF Tampa, Team 1-2, Sullivan Winter 2015 회원
USFT-SULLIVAN-W15S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 645
