주요 콘텐츠로 건너뛰기
Sony Action Cam Mini HDR-AZ1 Battery Door Replacement
필요한 것
  1. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: 1 단계, 이미지 1/3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: 1 단계, 이미지 2/3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery: 1 단계, 이미지 3/3
    • To access the battery, first make sure the camera is out of the case.
    • Push down on the door lock, located on the rear of the action cam.
    • The door is unlocked if the little yellow square is showing.
    • Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
  2. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 2 단계, 이미지 1/3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 2 단계, 이미지 2/3 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 2 단계, 이미지 3/3
    • Open the side panel outward to reveal the battery.
    • Be sure not to break the small piece of plastic securing the door to the camera.
    • Use the pull tab to pop the battery out of place.
  3. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: 3 단계, 이미지 1/2 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement, Battery Door: 3 단계, 이미지 2/2
    • Remove the circled 4 millimeter black screw adjacent to where the door is attached.
  4. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 4 단계, 이미지 1/2 Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 4 단계, 이미지 2/2
    • Grab the small black bracket holding the ribbon on which the door is attached and pull it out.
  5. Sony Action Cam Mini HDR-AZ1 Battery Door Replacement: 5 단계, 이미지 1/1
    • Pull the door straight back so the attaching ribbon is pulled taught and the door will come right off.
결론
Mathieu LaFond
회원 가입일: 10/27/15
425 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 6
전체 시간: 707
