주요 콘텐츠로 건너뛰기
Sony Action Cam Mini HDR-AZ1 Battery Replacement
  1. Sony Action Cam Mini HDR-AZ1 Battery Replacement, Battery: 1 단계, 이미지 1/3 Sony Action Cam Mini HDR-AZ1 Battery Replacement, Battery: 1 단계, 이미지 2/3 Sony Action Cam Mini HDR-AZ1 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • To access the battery, first make sure the camera is out of the case.
    • Push down on the door lock, located on the rear of the action cam.
    • The door is unlocked if the little yellow square is showing.
    • Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
  2. Sony Action Cam Mini HDR-AZ1 Battery Replacement: 2 단계, 이미지 1/3 Sony Action Cam Mini HDR-AZ1 Battery Replacement: 2 단계, 이미지 2/3 Sony Action Cam Mini HDR-AZ1 Battery Replacement: 2 단계, 이미지 3/3
    • Open the side panel outward to reveal the battery.
    • Be sure not to break the small piece of plastic securing the door to the camera.
    • Use the pull tab to pop the battery out of place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brody Bridges
회원 가입일: 10/29/15
101 평판
안내서 1개 작성함
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G7
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Comment changer la battrie du moniteur d'affichage ?
Claude Bouthé - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 1,117
