소개
Are you experiencing problems with the battery?
To access the battery, first make sure the camera is out of the case.
Push down on the door lock, located on the rear of the action cam.
Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
