주요 콘텐츠로 건너뛰기
Sony Action Cam Mini HDR-AZ1 Memory Card Replacement
  1. Sony Action Cam Mini HDR-AZ1 Memory Card Replacement, Memory Card: 1 단계, 이미지 1/1
    • To access the memory card, pull open the small dust door on the bottom right of the back of the camera.
  2. Sony Action Cam Mini HDR-AZ1 Memory Card Replacement: 2 단계, 이미지 1/3 Sony Action Cam Mini HDR-AZ1 Memory Card Replacement: 2 단계, 이미지 2/3 Sony Action Cam Mini HDR-AZ1 Memory Card Replacement: 2 단계, 이미지 3/3
    • Push inward on the back of the memory card with the tip of your finger until you feel a click and release.
    • Pinch the rear of the memory card that is protruding from the slot and pull outwards until the memory card is removed.
결론
To place a new memory card in, follow these instructions in reverse order.
Mathieu LaFond
회원 가입일: 10/27/15
425 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 538
