주요 콘텐츠로 건너뛰기
Sony Action Cam Mini HDR-AZ1 Protective Doors Replacement
  1. Sony Action Cam Mini HDR-AZ1 Protective Doors Replacement, Protective Doors: 1 단계, 이미지 1/1
    • Pull on the port door until it opens.
  2. Sony Action Cam Mini HDR-AZ1 Protective Doors Replacement: 2 단계, 이미지 1/1
    • Grasp the door and pull straight out. Don't worry, this will not break it.
  3. Sony Action Cam Mini HDR-AZ1 Protective Doors Replacement: 3 단계, 이미지 1/1
    • The door should pop out.
결론
To remove the SD card dust door, follow these exact steps. To reassemble your device, follow these instructions in reverse order.
Mathieu LaFond
회원 가입일: 10/27/15
425 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 263
