소개
This guide can help you open the front plate of your Sony Alpha A5100. For this guide, you will need a plastic opening tool and a Phillips PH00 screwdriver head. You will need to be gentle while opening up the plate.
Slide the power switch on the top of the camera to "off."
Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
Remove one 2mm Phillips #00 screw from the flash plate cover.
Use the spudger to pop the plate off.
Remove two 2mm Phillips #00 screws on the side of the camera.
