주요 콘텐츠로 건너뛰기
Sony Alpha 5100 Lens Replacement
  1. Sony Alpha 5100 Lens Replacement, Lens: 1 단계, 이미지 1/1
    • Place the camera in front so the lens is facing you. There should be a small button on the bottom left side of the lens.
  2. Sony Alpha 5100 Lens Replacement: 2 단계, 이미지 1/1
    • While holding down the button with your left thumb, use your right hand to twist the lens counterclockwise.
    • Make sure that you are twisting the bottom end of the lens.
  3. Sony Alpha 5100 Lens Replacement: 3 단계, 이미지 1/1
    • To insert a new lens, align the marking on the lens to the marking on the mount on the camera body.
    • Once insert correctly, you can twist the lens in clockwise direction easily until it clicks.
결론
Quang Phan
회원 가입일: 10/30/19
97 평판
안내서 1개 작성함
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 UMass Dartmouth, Team S4-G6, Saloman Fall 2019 회원
UMASSD-SALOMAN-F19S4G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 858
