주요 콘텐츠로 건너뛰기
Sony Alpha A3000 Battery Replacement
  1. Sony Alpha A3000 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • The battery compartment is located on the bottom of the camera as shown. To access the battery slide the compartment switch from LOCK to OPEN.
    • Before operating on device, ensure that the camera is powered off and the surface of operation is clean and free of dirt or other obstructions.
  2. Sony Alpha A3000 Battery Replacement: 2 단계, 이미지 1/1
    • Push back the blue tab releasing the battery which should spring forth on its own.
  3. Sony Alpha A3000 Battery Replacement: 3 단계, 이미지 1/1
    • To insert replacement, depress the blue tab again inserting the battery as shown until the blue tab springs back into place. Ensure battery is secure, close the battery compartment and return the latch to the LOCK position.
    • The replacement battery must meet specifications declared by Sony.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Junior Recinos
회원 가입일: 08/25/15
227 평판
안내서 1개 작성함
USF Tampa, Team 4-4, Meier Fall 2015 USF Tampa, Team 4-4, Meier Fall 2015 회원
USFT-MEIER-F15S4G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 2,183
