주요 콘텐츠로 건너뛰기
Sony Alpha A3000 Built-in flash Replacement
필요한 것
  1. Sony Alpha A3000 Built-in flash Replacement, Rear Case: 1 단계, 이미지 1/3 Sony Alpha A3000 Built-in flash Replacement, Rear Case: 1 단계, 이미지 2/3 Sony Alpha A3000 Built-in flash Replacement, Rear Case: 1 단계, 이미지 3/3
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 Built-in flash Replacement: 2 단계, 이미지 1/2 Sony Alpha A3000 Built-in flash Replacement: 2 단계, 이미지 2/2
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 Built-in flash Replacement: 3 단계, 이미지 1/2 Sony Alpha A3000 Built-in flash Replacement: 3 단계, 이미지 2/2
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 Built-in flash Replacement, Built-in flash: 4 단계, 이미지 1/1
    • Remove the single screw from the bottom of the flash device.
  5. Sony Alpha A3000 Built-in flash Replacement: 5 단계, 이미지 1/1
    • Remove the flash cover by gently pulling it in an outward direction.
  6. Sony Alpha A3000 Built-in flash Replacement: 6 단계, 이미지 1/1
    • Use a soldering tool to remove the three wires connecting the flash to the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Leonard Holloman
회원 가입일: 08/31/15
638 평판
안내서 4개 작성하였습니다
USF Tampa, Team 4-4, Meier Fall 2015 USF Tampa, Team 4-4, Meier Fall 2015 회원
USFT-MEIER-F15S4G4
4 회원들
안내서 10개 작성하였습니다
댓글 3개
Thx, saved me from draing costs for cleaning my viewfinder from watercolor paint. also hotshoe adapter disassembly was easier than other parts. be careful, if you want to do it!
Michael Smith - 답글
My LCD and viewfinder are not working anymore. I think is the flex that broke up... or the socket where is connected... And there is no replacement pieces in my country.......... As well as it is not a cheap camera for us........ I want to kill myself.........................
l2weenlive - 답글
Any procedure for SONY a6300 built-in flash replacement?
Vivek Dhar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,940
