주요 콘텐츠로 건너뛰기
Sony Alpha A3000 Motherboard Replacement
필요한 것
  1. Sony Alpha A3000 Motherboard Replacement, Rear Case: 1 단계, 이미지 1/3 Sony Alpha A3000 Motherboard Replacement, Rear Case: 1 단계, 이미지 2/3 Sony Alpha A3000 Motherboard Replacement, Rear Case: 1 단계, 이미지 3/3
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 Motherboard Replacement: 2 단계, 이미지 1/2 Sony Alpha A3000 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 Motherboard Replacement: 3 단계, 이미지 1/2 Sony Alpha A3000 Motherboard Replacement: 3 단계, 이미지 2/2
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 Sony Alpha A3000 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
    • Detach the facing for the memory dock.
  5. Sony Alpha A3000 Motherboard Replacement: 5 단계, 이미지 1/2 Sony Alpha A3000 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the eight screws securing the mount for the flash device.
  6. Sony Alpha A3000 Motherboard Replacement: 6 단계, 이미지 1/2 Sony Alpha A3000 Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the three remaining screws holding in the protective metal casing.
  7. Sony Alpha A3000 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the metal casing.
  8. Sony Alpha A3000 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove three screws holding down the motherboard .
  9. Sony Alpha A3000 Motherboard Replacement: 9 단계, 이미지 1/2 Sony Alpha A3000 Motherboard Replacement: 9 단계, 이미지 2/2
    • Detach the nine serial cables connecting it to the camera body.
  10. Sony Alpha A3000 Motherboard Replacement: 10 단계, 이미지 1/1
    • Finally remove the motherboard from the casing.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Leonard Holloman
회원 가입일: 08/31/15
638 평판
안내서 4개 작성하였습니다
USF Tampa, Team 4-4, Meier Fall 2015 USF Tampa, Team 4-4, Meier Fall 2015 회원
USFT-MEIER-F15S4G4
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Then loose the plug all the motherboard?
kongre172 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 26
전체 시간: 2,414
