주요 콘텐츠로 건너뛰기
Sony Alpha DSLR- A850 Focus lens Replacement
필요한 것
  1. Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: 1 단계, 이미지 1/3 Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: 1 단계, 이미지 2/3 Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: 1 단계, 이미지 3/3
    • Push in the button next to the lens.
    • While holding the button twist the lens counter-clockwise.
    • Pull up and remove lens from camera.
  2. Sony Alpha DSLR- A850 Focus lens Replacement: 2 단계, 이미지 1/3 Sony Alpha DSLR- A850 Focus lens Replacement: 2 단계, 이미지 2/3 Sony Alpha DSLR- A850 Focus lens Replacement: 2 단계, 이미지 3/3
    • Inside toward the top you will find a small slit in the plastic piece.
    • Insert a flat head screw driver into the slit and pull down to access the focus lens.
  3. Sony Alpha DSLR- A850 Focus lens Replacement: 3 단계, 이미지 1/3 Sony Alpha DSLR- A850 Focus lens Replacement: 3 단계, 이미지 2/3 Sony Alpha DSLR- A850 Focus lens Replacement: 3 단계, 이미지 3/3
    • Using tweezers grab the focus lens on the side by the two tabs that are on it.
    • Do not grab the focus lens in the middle as this will damage the lens.
    • Pull out and remove focus lens from camera.
  4. Sony Alpha DSLR- A850 Focus lens Replacement: 4 단계, 이미지 1/3 Sony Alpha DSLR- A850 Focus lens Replacement: 4 단계, 이미지 2/3 Sony Alpha DSLR- A850 Focus lens Replacement: 4 단계, 이미지 3/3
    • When inserting new focus make sure to orient it where the two tabs are facing towards you with the smaller tab facing up.
    • Angle the focus lens to make installation easier.
    • Lay the new focus lens into the plastic tray.
    • It does not snap into place.
  5. Sony Alpha DSLR- A850 Focus lens Replacement: 5 단계, 이미지 1/2 Sony Alpha DSLR- A850 Focus lens Replacement: 5 단계, 이미지 2/2
    • Insert screw driver into the slit and push up to close.
    • You can also use your thumb, if you are careful not to touch the lens as this could leave a smudge on the lens.
    • You will hear a click when the plastic tray is back in place.
  6. Sony Alpha DSLR- A850 Focus lens Replacement: 6 단계, 이미지 1/2 Sony Alpha DSLR- A850 Focus lens Replacement: 6 단계, 이미지 2/2
    • When re-installing the lens line up the orange dots that are one both lens and camera.
    • Fit lens into place and turn clockwise to secure it back to camera.
결론
You have now completed a focus lens replacement.
Walter Littlefield
회원 가입일: 03/21/18
265 평판
안내서 2개 작성하였습니다
University of Memphis, Team S2-G4, Kim Spring 2018 University of Memphis, Team S2-G4, Kim Spring 2018 회원
UM-KIM-S18S2G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 9
전체 시간: 735
