주요 콘텐츠로 건너뛰기
Sony Alpha DSLR- A850 Focusing Screen Replacement
필요한 것
  1. Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: 1 단계, 이미지 3개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: 1 단계, 이미지 3개 중 2개 Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: 1 단계, 이미지 3개 중 3개
    • Push in the button next to the lens.
    • While holding the button twist the lens counter-clockwise.
    • Pull up and remove lens from camera.
  2. Sony Alpha DSLR- A850 Focusing Screen Replacement: 2 단계, 이미지 3개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 2 단계, 이미지 3개 중 2개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Inside toward the top you will find a small slit in the plastic piece.
    • Insert a flat head screw driver into the slit and pull down to access the focusing screen.
  3. Sony Alpha DSLR- A850 Focusing Screen Replacement: 3 단계, 이미지 3개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 3 단계, 이미지 3개 중 2개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using tweezers grab the focusing screen on the side by the two tabs that are on it.
    • Do not grab the focusing screen in the middle as this will damage it.
    • Pull out and remove focusing screen from camera.
  4. Sony Alpha DSLR- A850 Focusing Screen Replacement: 4 단계, 이미지 3개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 4 단계, 이미지 3개 중 2개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 4 단계, 이미지 3개 중 3개
    • When inserting new screen make sure to orient it where the two tabs are facing towards you with the smaller tab facing up.
    • Angle the focusing screen to make installation easier.
    • Lay the new focusing screen into the plastic tray.
    • It does not snap into place.
  5. Sony Alpha DSLR- A850 Focusing Screen Replacement: 5 단계, 이미지 2개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Insert screw driver into the slit and push up to close.
    • You can also use your thumb, if you are careful not to touch the screen as this could leave a smudge on it.
    • You will hear a click when the plastic tray is back in place.
  6. Sony Alpha DSLR- A850 Focusing Screen Replacement: 6 단계, 이미지 2개 중 1개 Sony Alpha DSLR- A850 Focusing Screen Replacement: 6 단계, 이미지 2개 중 2개
    • When re-installing the lens line up the orange dots that are one both lens and camera.
    • Fit lens into place and turn clockwise to secure it back to camera.
결론
You have now completed a focusing screen replacement.
작성자
3다른 기여자 명과 함께
Walter Littlefield
회원 가입일: 03/21/18
265 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 24
전체 시간: 1,054
