주요 콘텐츠로 건너뛰기
Sony Alpha DSLR- A850 Viewfinder Cover Replacement
필요한 것
  1. Sony Alpha DSLR- A850 Viewfinder Cover Replacement, Viewfinder Cover: 1 단계, 이미지 1/1
    • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
  2. Sony Alpha DSLR- A850 Viewfinder Cover Replacement: 2 단계, 이미지 1/1
    • Slide the rubber piece off.
    • There may be a slight popping sound.
  3. Sony Alpha DSLR- A850 Viewfinder Cover Replacement: 3 단계, 이미지 1/1
    • Once the rubber piece has been removed, inspect the area.
    • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
결론
Sukanya D
회원 가입일: 03/21/18
197 평판
안내서 1개 작성함
University of Memphis, Team S2-G4, Kim Spring 2018 University of Memphis, Team S2-G4, Kim Spring 2018 회원
UM-KIM-S18S2G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 419
