주요 콘텐츠로 건너뛰기
Sony Alpha DSLR- A850 Viewfinder Window Replacement
필요한 것
  1. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Cover: 1 단계, 이미지 1개 중 1개
    • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
  2. Sony Alpha DSLR- A850 Viewfinder Window Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the rubber piece off.
    • There may be a slight popping sound.
  3. Sony Alpha DSLR- A850 Viewfinder Window Replacement: 3 단계, 이미지 1개 중 1개
    • Once the rubber piece has been removed, inspect the area.
    • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
  4. Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: 4 단계, 이미지 2개 중 1개 Sony Alpha DSLR- A850 Viewfinder Window Replacement, Viewfinder Window: 4 단계, 이미지 2개 중 2개
    • Remove all four screws from the viewfinder.
  5. Sony Alpha DSLR- A850 Viewfinder Window Replacement: 5 단계, 이미지 2개 중 1개 Sony Alpha DSLR- A850 Viewfinder Window Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Grasp the side of the window with either a set of tweezers or your fingers. Lift upwards and slightly towards the base of the camera.
  6. Sony Alpha DSLR- A850 Viewfinder Window Replacement: 6 단계, 이미지 1개 중 1개
    • To reinsert the window, push inward and slightly forward. There is a tab on the camera that the window must catch on in order to be put into place.
결론
작성자
3다른 기여자 명과 함께
Richard Fabian
회원 가입일: 03/21/18
256 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 729
