주요 콘텐츠로 건너뛰기
Sony Alpha ILCE-6000 E-mount Replacement
필요한 것
  1. Sony Alpha ILCE-6000 E-mount Replacement, Lens: 1 단계, 이미지 1/1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 E-mount Replacement: 2 단계, 이미지 1/1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 E-mount Replacement: 3 단계, 이미지 1/2 Sony Alpha ILCE-6000 E-mount Replacement: 3 단계, 이미지 2/2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
  4. Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: 4 단계, 이미지 1/2 Sony Alpha ILCE-6000 E-mount Replacement, E-mount Replacement: 4 단계, 이미지 2/2
    • Locate the E-mount on the front of the camera
  5. Sony Alpha ILCE-6000 E-mount Replacement: 5 단계, 이미지 1/3 Sony Alpha ILCE-6000 E-mount Replacement: 5 단계, 이미지 2/3 Sony Alpha ILCE-6000 E-mount Replacement: 5 단계, 이미지 3/3
    • Take a Philips head 00 screw to remove the four of the 5.1mm screws located on the E-mount.
  6. Sony Alpha ILCE-6000 E-mount Replacement: 6 단계, 이미지 1/3 Sony Alpha ILCE-6000 E-mount Replacement: 6 단계, 이미지 2/3 Sony Alpha ILCE-6000 E-mount Replacement: 6 단계, 이미지 3/3
    • After removing the screws, pull off the E-mount metal ring gently and wiggle it until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the metal piece that is located behind the plastic ring.
  7. Sony Alpha ILCE-6000 E-mount Replacement: 7 단계, 이미지 1/1
    • Replace the plastic E-mount ring with a new one.
결론
Yirga Yilma
회원 가입일: 02/02/17
221 평판
안내서 2개 작성하였습니다
UW Tacoma, Team 1-4, Rose Winter 2017 UW Tacoma, Team 1-4, Rose Winter 2017 회원
UWT-ROSE-W17S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 2개
Hello folks,
actually I have to replace the E-mount ring my ILCE-6000, which seems very easy with this description. Thanks a lot for this!
Is the ring available anywhere on this globe? I would truly appreciate any hint.
Best regards, JDK
JDK - 답글
Hi there, found a source for the ring as original part. The price is reasonable. Now waiting for delivery ...
Best regards, JDK
JDK - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 75
전체 시간: 3,643
