주요 콘텐츠로 건너뛰기
Sony Alpha ILCE-6000 Lens Replacement
필요한 것
  1. Sony Alpha ILCE-6000 Lens Replacement, Lens: 1 단계, 이미지 1/1
    • Turn of camera by turning the switch to OFF.
  2. Sony Alpha ILCE-6000 Lens Replacement: 2 단계, 이미지 1/1
    • Use the finger, press and hold the release black circle button ( on the bottom ) next to the lens on the front of the camera.
  3. Sony Alpha ILCE-6000 Lens Replacement: 3 단계, 이미지 1/2 Sony Alpha ILCE-6000 Lens Replacement: 3 단계, 이미지 2/2
    • Using the left hand or the right hand to hold the camera body, other hand twist the lens counterclockwise and pull it off.
    • Align the white dot of the lens to the white dot on the camera mount to completely replace.
결론
Vuong Nguyen
회원 가입일: 02/02/17
122 평판
안내서 1개 작성함
UW Tacoma, Team 1-4, Rose Winter 2017 UW Tacoma, Team 1-4, Rose Winter 2017 회원
UWT-ROSE-W17S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
my camera will not recognize my lens, optical steady shot 1650. it used to work fine, but I dropped it. now the camera says it's not attached properly. any suggestions?
Connie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 37
전체 시간: 1,970
