주요 콘텐츠로 건너뛰기
Sony Alpha NEX-3N LCD assembly Replacement
필요한 것
  1. Sony Alpha NEX-3N LCD assembly Replacement, Getting Started: 1 단계, 이미지 1/2 Sony Alpha NEX-3N LCD assembly Replacement, Getting Started: 1 단계, 이미지 2/2
    • Remove battery and card
  2. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: 2 단계, 이미지 1/3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: 2 단계, 이미지 2/3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: 2 단계, 이미지 3/3
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 2: 3 단계, 이미지 1/1
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: 4 단계, 이미지 1/3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: 4 단계, 이미지 2/3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: 4 단계, 이미지 3/3
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N LCD assembly Replacement, LCD assembly: 5 단계, 이미지 1/2 Sony Alpha NEX-3N LCD assembly Replacement, LCD assembly: 5 단계, 이미지 2/2
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: 6 단계, 이미지 1/3 Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: 6 단계, 이미지 2/3 Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: 6 단계, 이미지 3/3
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N LCD assembly Replacement, The LCD assembly: 7 단계, 이미지 1/1
    • The LCD assembly
결론
Terrance
회원 가입일: 11/17/09
6,368 평판
안내서 17개 작성하였습니다
댓글 한 개
Where can i get a lcd screen replacement?
Searched everywhere even AliExpress they do not sell the replacement lcd for this model
adfa dad - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 41
전체 시간: 1,098
