주요 콘텐츠로 건너뛰기
Sony Alpha NEX-3N Shutter Replacement
필요한 것
  1. Sony Alpha NEX-3N Shutter Replacement, Getting Started: 1 단계, 이미지 1/2 Sony Alpha NEX-3N Shutter Replacement, Getting Started: 1 단계, 이미지 2/2
    • Remove battery and card
  2. Sony Alpha NEX-3N Shutter Replacement, Back Case 1: 2 단계, 이미지 1/3 Sony Alpha NEX-3N Shutter Replacement, Back Case 1: 2 단계, 이미지 2/3 Sony Alpha NEX-3N Shutter Replacement, Back Case 1: 2 단계, 이미지 3/3
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N Shutter Replacement, Back Case 2: 3 단계, 이미지 1/1
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N Shutter Replacement, Back Case 3: 4 단계, 이미지 1/3 Sony Alpha NEX-3N Shutter Replacement, Back Case 3: 4 단계, 이미지 2/3 Sony Alpha NEX-3N Shutter Replacement, Back Case 3: 4 단계, 이미지 3/3
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N Shutter Replacement, LCD assembly: 5 단계, 이미지 1/2 Sony Alpha NEX-3N Shutter Replacement, LCD assembly: 5 단계, 이미지 2/2
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N Shutter Replacement, LCD Assembly: 6 단계, 이미지 1/3 Sony Alpha NEX-3N Shutter Replacement, LCD Assembly: 6 단계, 이미지 2/3 Sony Alpha NEX-3N Shutter Replacement, LCD Assembly: 6 단계, 이미지 3/3
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N Shutter Replacement, The LCD assembly: 7 단계, 이미지 1/1
    • The LCD assembly
  8. Sony Alpha NEX-3N Shutter Replacement, Keypad: 8 단계, 이미지 1/3 Sony Alpha NEX-3N Shutter Replacement, Keypad: 8 단계, 이미지 2/3 Sony Alpha NEX-3N Shutter Replacement, Keypad: 8 단계, 이미지 3/3
    • Lift the keypad.
    • Detach FPC
  9. Sony Alpha NEX-3N Shutter Replacement, Screws: 9 단계, 이미지 1/1
    • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
  10. Sony Alpha NEX-3N Shutter Replacement: 10 단계, 이미지 1/2 Sony Alpha NEX-3N Shutter Replacement: 10 단계, 이미지 2/2
    • Slide the flash assembly backwards with caution.
    • Detach flash FPC by pulling it out of the socket.
    • High Voltage! Do NOT touch metal on FPC.
    • Then remove the flash assembly.
  11. Sony Alpha NEX-3N Shutter Replacement: 11 단계, 이미지 1/1
    • Remove that part whatever called, by sliding it backwards.
  12. Sony Alpha NEX-3N Shutter Replacement, Screws: 12 단계, 이미지 1/3 Sony Alpha NEX-3N Shutter Replacement, Screws: 12 단계, 이미지 2/3 Sony Alpha NEX-3N Shutter Replacement, Screws: 12 단계, 이미지 3/3
    • 1 ST1.7x5
    • 2 ST1.7x5
    • 1 M1.4x3.6 black
  13. Sony Alpha NEX-3N Shutter Replacement, The Grip: 13 단계, 이미지 1/2 Sony Alpha NEX-3N Shutter Replacement, The Grip: 13 단계, 이미지 2/2
    • Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
    • Pop the grip off. From back, push to the right, then it flies forward.
  14. Sony Alpha NEX-3N Shutter Replacement, More Screws: 14 단계, 이미지 1/1
    • Remove 2 M1.4x2 black screws
  15. Sony Alpha NEX-3N Shutter Replacement, Pop the Shielding Cover: 15 단계, 이미지 1/2 Sony Alpha NEX-3N Shutter Replacement, Pop the Shielding Cover: 15 단계, 이미지 2/2
    • with caution and patient.
  16. Sony Alpha NEX-3N Shutter Replacement, One More Shield: 16 단계, 이미지 1/3 Sony Alpha NEX-3N Shutter Replacement, One More Shield: 16 단계, 이미지 2/3 Sony Alpha NEX-3N Shutter Replacement, One More Shield: 16 단계, 이미지 3/3
    • 1 M1.4x3.6
  17. Sony Alpha NEX-3N Shutter Replacement, Detach 7000 FPCs: 17 단계, 이미지 1/1
    • Sensor power, flip
    • Sensor signal, flip
    • Shutter, pull
    • Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
    • Whatever, pull
    • Whatever, pull
    • Shutter charger motor FPC, (backside, pull out)
  18. Sony Alpha NEX-3N Shutter Replacement: 18 단계, 이미지 1/1
    • Flip the Mainboard up
    • Pull out one more FPC
    • Discharge then desolder 4 wires.
    • CAUTION! Possible high DC voltage >300V
  19. Sony Alpha NEX-3N Shutter Replacement: 19 단계, 이미지 1/1
    • Lift main board and plastic frame with flash capacitor.
  20. Sony Alpha NEX-3N Shutter Replacement, FPC cables: 20 단계, 이미지 1/1
    • Detach sensor Power (L)and Signal(R) FPC
  21. Sony Alpha NEX-3N Shutter Replacement, Screws: 21 단계, 이미지 1/1
    • Remove 3-4 ST1.7x5 screws
    • Remove 1 M1.4x5 screw
  22. Sony Alpha NEX-3N Shutter Replacement: 22 단계, 이미지 1/2 Sony Alpha NEX-3N Shutter Replacement: 22 단계, 이미지 2/2
    • Remove 4 ST1.7x5 screws for the E-Mount
    • Remove mount metal ring
  23. Sony Alpha NEX-3N Shutter Replacement, E-Mount: 23 단계, 이미지 1/3 Sony Alpha NEX-3N Shutter Replacement, E-Mount: 23 단계, 이미지 2/3 Sony Alpha NEX-3N Shutter Replacement, E-Mount: 23 단계, 이미지 3/3
    • Remove mount plastic ring
    • remove mount spring ring
  24. Sony Alpha NEX-3N Shutter Replacement, Sensor + Shutter: 24 단계, 이미지 1/1
    • Sensor + Shutter assembly comes off
  25. Sony Alpha NEX-3N Shutter Replacement, Sensor Frame: 25 단계, 이미지 1/1
    • Separate sensor + shutter from another frame
  26. Sony Alpha NEX-3N Shutter Replacement, The Sensor: 26 단계, 이미지 1/3 Sony Alpha NEX-3N Shutter Replacement, The Sensor: 26 단계, 이미지 2/3 Sony Alpha NEX-3N Shutter Replacement, The Sensor: 26 단계, 이미지 3/3
    • Remove 3 ST1.7x5 screws
    • Remove sensor shield / heat sink. Sensor PCBA might sticks to the shield, just separate them.
  27. Sony Alpha NEX-3N Shutter Replacement, Shutter: 27 단계, 이미지 1/2 Sony Alpha NEX-3N Shutter Replacement, Shutter: 27 단계, 이미지 2/2
    • Remove sensor. the shutter assembly comes off.
    • Careful with 3 tiny spacers. Do NOT lose them.
  28. Sony Alpha NEX-3N Shutter Replacement: 28 단계, 이미지 1/1
    • Separate Shutter assembly form the mount body.
  29. Sony Alpha NEX-3N Shutter Replacement: 29 단계, 이미지 1/3 Sony Alpha NEX-3N Shutter Replacement: 29 단계, 이미지 2/3 Sony Alpha NEX-3N Shutter Replacement: 29 단계, 이미지 3/3
    • Remove 1 screw (from the "Front" side)
    • Separate shutter curtain (Photo 3) from charging motor (not shown).
결론
Terrance
회원 가입일: 11/17/09
6,377 평판
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 25
전체 시간: 515
