주요 콘텐츠로 건너뛰기
Sony Alpha NEX-5N Battery Replacement
  1. Sony Alpha NEX-5N Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before operating on this device, be sure the device is turned off.
    • Turn the device off by switching the power knob to face the word "OFF".
  2. Sony Alpha NEX-5N Battery Replacement: 2 단계, 이미지 1/2 Sony Alpha NEX-5N Battery Replacement: 2 단계, 이미지 2/2
    • Flip the device upside-down and gently place it down on a flat surface.
    • Locate the battery compartment, which is indicated by a grooved latch.
    • Push the latch to the right so that the arrow is positioned above the word "Open". The door should then flip upward.
  3. Sony Alpha NEX-5N Battery Replacement: 3 단계, 이미지 1/2 Sony Alpha NEX-5N Battery Replacement: 3 단계, 이미지 2/2
    • With the battery compartment latch open, locate the lock lever.
    • Press the lock lever to the left. This will eject the camera battery.
결론
Demi Deletang
회원 가입일: 09/28/15
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 50
전체 시간: 2,455
