주요 콘텐츠로 건너뛰기
Sony Alpha NEX-5N E-mount Replacement
필요한 것
  1. Sony Alpha NEX-5N E-mount Replacement, E-mount: 1 단계, 이미지 1/2 Sony Alpha NEX-5N E-mount Replacement, E-mount: 1 단계, 이미지 2/2
    • While completing this guide, do not touch the image sensor (the center rectangle encircled by the lens mount).
    • Unscrew the 4 silver 1.2 mm Phillips #000 screws along the front outer lens mount.
    • Applying extra force to unscrew these 4 screws may be necessary.
    • Detach the outer lens mount ring.
  2. Sony Alpha NEX-5N E-mount Replacement: 2 단계, 이미지 1/2 Sony Alpha NEX-5N E-mount Replacement: 2 단계, 이미지 2/2
    • Pay attention to the positioning and order of the spacing rings for reassembly.
    • Using your fingers, pull out the first black spacer ring.
    • Repeat the previous step for the second silver spacer ring.
  3. Sony Alpha NEX-5N E-mount Replacement: 3 단계, 이미지 1/3 Sony Alpha NEX-5N E-mount Replacement: 3 단계, 이미지 2/3 Sony Alpha NEX-5N E-mount Replacement: 3 단계, 이미지 3/3
    • Unscrew the 2 silver 1.2 mm Phillips #000 screws on opposing sides in the lens ring area.
    • Using your fingers, easily pull off lens housing. This will complete the removal of the E-mount.
    • The lens release button and the small spring underneath will be loose.
결론
Andrea Tobar
회원 가입일: 09/28/15
294 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 24
전체 시간: 1,299
