주요 콘텐츠로 건너뛰기
Sony Alpha NEX-6 Battery Replacement
필요한 것
  1. Sony Alpha NEX-6 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
  2. Sony Alpha NEX-6 Battery Replacement: 2 단계, 이미지 1/1
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
  3. Sony Alpha NEX-6 Battery Replacement: 3 단계, 이미지 1/1
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Clayton Dale
회원 가입일: 01/20/15
1,067 평판
안내서 7개 작성하였습니다
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G2
4 회원들
안내서 14개 작성하였습니다
댓글 3개
Will not spring out. Any ideas?
rustychinnis - 답글
Got it, battery damaged. Tapped on edge to remove battery
rustychinnis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 19
전체 시간: 2,399
