주요 콘텐츠로 건너뛰기
Sony Alpha NEX-6 LCD Screen Replacement
필요한 것
  1. Sony Alpha NEX-6 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
    • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
  2. Sony Alpha NEX-6 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the camera upside-down and carefully place it on a flat surface.
    • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
    • Push the latch to the right to unlock the battery compartment. The door should flip upward.
  3. Sony Alpha NEX-6 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • With the compartment open, locate a blue tab shown with spudger
    • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
  4. Sony Alpha NEX-6 LCD Screen Replacement, Removing back screws: 4 단계, 이미지 1개 중 1개
    • Remove the two 1.0 mm Phillips #00 screws from back of the LCD screen.
  5. Sony Alpha NEX-6 LCD Screen Replacement, Removing bottom screws: 5 단계, 이미지 1개 중 1개
    • Remove the two 1.5 mm Phillips #00 screws from the bottom of the screen mount assembly.
  6. Sony Alpha NEX-6 LCD Screen Replacement, Back cover: 6 단계, 이미지 2개 중 1개 Sony Alpha NEX-6 LCD Screen Replacement, Back cover: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using a plastic opening tool pry off the back cover from the screen assembly.
    • Remove back cover by lifting it away from the screen using tweezers.
  7. Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: 7 단계, 이미지 3개 중 1개 Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: 7 단계, 이미지 3개 중 2개 Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: 7 단계, 이미지 3개 중 3개
    • Release the ribbon cable by lifting the black locking latch with the plastic opening tool.
    • Pry out the ribbon cable by carefully sliding it out of the connection slot using a spudger.
  8. Sony Alpha NEX-6 LCD Screen Replacement, Upper plastic separator: 8 단계, 이미지 1개 중 1개
    • Lift and slide out the upper black plastic separator using tweezers.
  9. Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: 9 단계, 이미지 3개 중 1개 Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: 9 단계, 이미지 3개 중 2개 Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: 9 단계, 이미지 3개 중 3개
    • Lift and remove the lower black plastic separator using tweezers.
    • Using the pointy side of a spudger push in the screen lock button release it.
    • The screen lock button can now be removed.
  10. Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: 10 단계, 이미지 3개 중 1개 Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: 10 단계, 이미지 3개 중 2개 Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: 10 단계, 이미지 3개 중 3개
    • Using the flat end of the spudger, push on the black nylon sheet glued to the metallic frame to peel it of.
    • Apply force from different spots to avoid tearing the sheet.
    • Remove the black nylon sheet using tweezers.
  11. Sony Alpha NEX-6 LCD Screen Replacement, Screen Removal: 11 단계, 이미지 1개 중 1개
    • Gently wiggle the screen loose and remove it from the mount.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Clayton Dale
회원 가입일: 01/20/15
1,067 평판
안내서 7개를 작성함
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G2
4 회원들
안내서 14개를 작성함
2가이드 댓글
Thanks a million! Great guide and saved me $250 sending it back in.
Al Weiner - 답글
Hi - I am trying to fix one of these -- and the guy I bought it from pulled off and lost the black locking latch from the ribbon cable rather than just lifting it -- I can get the LCD screen to light but can't keep it on very long -- I bought another one of these internal cables with the black locking latch. Do you think I can pop that one off and move it to this one? Or do you have any source of instructions how to replace that cable?
Cheers and thanks for this!
PS -- If anyone is just trying to get rid of the dreaded bubbles in the screen saver that plagues these NEX cameras -- it does just peal off -- see youtubes,,,
Harvey Cat - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 80
전체 시간: 7,637
