필요한 것
Turn the camera with the lens facing up.
Find the lens release button - located along the side of the silver lens mount.
Press and hold the lens release button while rotating the lens counterclockwise.
Lift the lens when it is no longer attached to the camera.
After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
The outer lens mount ring can now be removed.
다른 3명이 해당 안내서를 완성하였습니다.
