주요 콘텐츠로 건너뛰기
Sony Alpha NEX-6 Lens Replacement
  1. Sony Alpha NEX-6 Lens Replacement, Finding the Release Button: 1 단계, 이미지 1/1
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens Replacement, Removing the Lens: 2 단계, 이미지 1/2 Sony Alpha NEX-6 Lens Replacement, Removing the Lens: 2 단계, 이미지 2/2
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
결론
The procedure to disassemble this lens is different from reassembly. This guide encompasses both processes.
다른 2명이 해당 안내서를 완성하였습니다.
Clayton Dale
회원 가입일: 01/20/15
1,067 평판
안내서 7개 작성하였습니다
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G2
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 2,565
