주요 콘텐츠로 건너뛰기
Sony Alpha NEX-6 Lens-release Button Replacement
필요한 것
  1. Sony Alpha NEX-6 Lens-release Button Replacement, Finding the Release Button: 1 단계, 이미지 1개 중 1개
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: 2 단계, 이미지 2개 중 1개 Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: 2 단계, 이미지 2개 중 2개
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
  3. Sony Alpha NEX-6 Lens-release Button Replacement, Lens Mount: 3 단계, 이미지 1개 중 1개
    • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
    • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
    • The outer lens mount ring can now be removed.
  4. Sony Alpha NEX-6 Lens-release Button Replacement: 4 단계, 이미지 3개 중 1개 Sony Alpha NEX-6 Lens-release Button Replacement: 4 단계, 이미지 3개 중 2개 Sony Alpha NEX-6 Lens-release Button Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Pay attention to the positioning of the spacer rings for reassembly.
    • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
    • Repeat this step for the second (silver) spacer ring.
    • The third image is what the camera should look like after all spacer rings are removed.
  5. Sony Alpha NEX-6 Lens-release Button Replacement: 5 단계, 이미지 2개 중 1개 Sony Alpha NEX-6 Lens-release Button Replacement: 5 단계, 이미지 2개 중 2개
    • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
  6. Sony Alpha NEX-6 Lens-release Button Replacement, Lens-release Button: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • By using tweezers, carefully remove the lens-release button by lifting upward.
결론
작성자
4다른 기여자 명과 함께
Clayton Dale
회원 가입일: 01/20/15
1,067 평판
안내서 7개를 작성함
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G2
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 1,608
