주요 콘텐츠로 건너뛰기
Sony Alpha NEX-C3 LCD Screen Replacement
필요한 것
  1. Sony Alpha NEX-C3 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Turn off the camera by sliding the power switch.
  2. Sony Alpha NEX-C3 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Tilt up the LCD screen.
  3. Sony Alpha NEX-C3 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Use a Phillips head 000 screwdriver to remove the two 2.0mm screws on the bottom of the LCD screen.
  4. Sony Alpha NEX-C3 LCD Screen Replacement: 4 단계, 이미지 1/3 Sony Alpha NEX-C3 LCD Screen Replacement: 4 단계, 이미지 2/3 Sony Alpha NEX-C3 LCD Screen Replacement: 4 단계, 이미지 3/3
    • Use a Phillips head 000 screwdriver to remove the two 1.0mm screws on the smaller backplate of the LCD screen that covers the ribbon cable.
    • The smaller backplate should easily come off. Put it to the side.
  5. Sony Alpha NEX-C3 LCD Screen Replacement: 5 단계, 이미지 1/2 Sony Alpha NEX-C3 LCD Screen Replacement: 5 단계, 이미지 2/2
    • Use a Phillips head 000 screwdriver to remove the two 1.0mm screws on the bigger backplate of the LCD.
  6. Sony Alpha NEX-C3 LCD Screen Replacement: 6 단계, 이미지 1/2 Sony Alpha NEX-C3 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, remove the larger backplate from the LCD screen.
  7. Sony Alpha NEX-C3 LCD Screen Replacement: 7 단계, 이미지 1/1
    • With your hands, gently remove the black plastic piece on the backside of the LCD screen.
  8. Sony Alpha NEX-C3 LCD Screen Replacement: 8 단계, 이미지 1/2 Sony Alpha NEX-C3 LCD Screen Replacement: 8 단계, 이미지 2/2
    • Using tweezers, gently pull up and away on the ribbon cable connected to the motherboard, after which, the LCD screen should come off.
    • The motherboard ribbon cable has a specific connector.
결론
To reassemble your device, follow these instructions in reverse order. However, when installing the ribbon cable, the connector has a specific step. The connector has a tiny flap that clamps down onto the ribbon cable in order to make it secure.
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Chen
회원 가입일: 10/17/17
690 평판
안내서 6개 작성하였습니다
UC Santa Barbara, Team S1-G1, Weedon Fall 2017 UC Santa Barbara, Team S1-G1, Weedon Fall 2017 회원
UCSB-WEEDON-F17S1G1
3 회원들
안내서 13개 작성하였습니다
댓글 한 개
Sir, my unit has many lines that appear on the screen. However, the lcd glass is pristine & has no cracks. Which part is defective? Is the lcd mother board the culprit? Thank you.
Stevie B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 23
전체 시간: 2,450
