주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The lens mount can wear over time and improper installation of the lens could break the inner plastic ring of the lens mount.
부품
지정된 부품이 없습니다.
  1. Turn the camera off by sliding the power switch.
    • Turn the camera off by sliding the power switch.
  2. Use a Phillips head 000 screwdriver to remove the four 5.0mm screws on the E-mount.
    • Use a Phillips head 000 screwdriver to remove the four 5.0mm screws on the E-mount.
  3. Press on the lens mount button with one hand. With the other hand, grab and gently wiggle off the E-mount metal ring until its free. Remove the plastic ring located under the metal ring.
    • Press on the lens mount button with one hand.
    • With the other hand, grab and gently wiggle off the E-mount metal ring until its free.
    • Remove the plastic ring located under the metal ring.
    • Do not remove the thin metal piece behind the plastic ring.
결론
Jonathan Chen
회원 가입일: 2017년 10월 17일
645 평판
안내서 6개 작성하였습니다
UC Santa Barbara, Team S1-G1, Weedon Fall 2017 UC Santa Barbara, Team S1-G1, Weedon Fall 2017 회원
UCSB-WEEDON-F17S1G1
3 회원들
안내서 13개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 349
