주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Alpha SLT-A55V Battery Replacement
필요한 것
  1. Sony Alpha SLT-A55V Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the battery compartment on the bottom of the unit. Then, slide the latch down to open the cover.
  2. Sony Alpha SLT-A55V Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the new battery and close the compartment.
    • Most new lithium batteries are partially charged to improve shelf life. It is recommended to charge the battery after installation even if the indicator shows a full charge. Unlike nickel cadmium batteries, lithium batteries will provide better performance when charged to full capacity from a partial charge of 60%.
결론
There you go, now you have a fully functional camera again. Do not forget to recharge the other battery to be prepared to repeat this guide.
작성자
5다른 기여자 명과 함께
Sultan Almunif
회원 가입일: 09/26/15
357 평판
안내서 3개를 작성함
IUPUI, Team 1-1, Wilson Fall 2015 IUPUI, Team 1-1, Wilson Fall 2015 회원
IUPUI-WILSON-F15S1G1
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 22
전체 시간: 2,017
