주요 콘텐츠로 건너뛰기
Sony Alpha a7S II Motherboard Replacement
필요한 것
  1. Sony Alpha a7S II Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Remove the six 4mm screws located at the bottom of the camera using Philips #000 (Circled in red).
    • Remove the two 3mm screws remaining on the base plate using Philips #000 (Circled in orange).
    • Remove the base plate.
  2. Sony Alpha a7S II Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Sony Alpha a7S II Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Sony Alpha a7S II Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use the Philips #000 to remove the two 4mm screws located inside the battery holder.
    • Next, remove the two 4mm screws using the Philips #000 located on left side of the camera.
    • Remove one 4mm screw on the right side of the camera using Philips #000.
  3. Sony Alpha a7S II Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 3mm screws from the underneath the LCD screen.
    • Remove the screen.
  4. Sony Alpha a7S II Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Sony Alpha a7S II Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the rubber viewfinder cap by sliding it upwards.
    • Remove the four 3mm screws behind the cap.
  5. Sony Alpha a7S II Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Sony Alpha a7S II Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the outer case.
    • Unhook the component outlined by the red square.
    • Next, unscrew the two 4mm screws circled in orange using the Philips #000.
    • Remove the button outlined with the yellow square.
  6. Sony Alpha a7S II Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Sony Alpha a7S II Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the 4 mm screw from the housing.
    • The access door on the side of the camera must be open to reach the screw and remove the copper plate.
  7. Sony Alpha a7S II Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Sony Alpha a7S II Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Sony Alpha a7S II Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Gently pull the clip up on the wire ribbon ports.
    • Using the tweezers, gently pull the wire ribbons out of the ports.
    • Once the ribbon cables are disconnected, the motherboard can be removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Alicia Alanis-Angeles
회원 가입일: 04/12/22
148 평판
안내서 1개를 작성함
IUPUI, Team 1-5, Beck Spring 2022 IUPUI, Team 1-5, Beck Spring 2022 회원
IUPUI-BECK-S22S1G5
4 회원들
안내서 2개를 작성함
2가이드 댓글
Where can I order the motherboard for this camera?
Joshua Davis - 답글
You can find replacement parts on Aliexpress.
Lou Bariller -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 96
전체 시간: 4,108
