주요 콘텐츠로 건너뛰기
Sony Alpha a7S II Viewfinder Plate Replacement
필요한 것
  1. Sony Alpha a7S II Viewfinder Plate Replacement, Diopter: 1 단계, 이미지 1개 중 1개
    • Orient your camera so that you are looking at the posterior portion.
  2. Sony Alpha a7S II Viewfinder Plate Replacement: 2 단계, 이미지 1개 중 1개
    • Place each of your thumbs on the interior portions of the eyepiece cup, pressing down and pushing up.
  3. Sony Alpha a7S II Viewfinder Plate Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the eyepiece off by carefully pulling it upward.
    • Be careful not to come into contact with the viewfinder lens as the lens can be easily scratched.
  4. Sony Alpha a7S II Viewfinder Plate Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the screw from the middle of the diopter with the JIS #00 screwdriver.
  5. Sony Alpha a7S II Viewfinder Plate Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the diopter with your hands. If the diopter is at all stuck you can use the pointed tweezers to help aid in the removal process.
    • Be careful not to let fingers or tweezers come into contact with the viewfinder lens as the lens can be easily scratched.
  6. Sony Alpha a7S II Viewfinder Plate Replacement, Viewfinder Plate: 6 단계, 이미지 1개 중 1개
    • Remove the 4 screws on the viewfinder plate with a JIS #00 screwdriver.
  7. Sony Alpha a7S II Viewfinder Plate Replacement: 7 단계, 이미지 2개 중 1개 Sony Alpha a7S II Viewfinder Plate Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully remove the plastic viewfinder plate from the camera.
결론
다른 3명이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 36
전체 시간: 5,295
