주요 콘텐츠로 건너뛰기
Sony Alpha a7s II Diopter Replacement
필요한 것
  1. Sony Alpha a7s II Diopter Replacement, Diopter: 1 단계, 이미지 1/1
    • Orient your camera so that you are looking at the posterior portion.
  2. Sony Alpha a7s II Diopter Replacement: 2 단계, 이미지 1/1
    • Place each of your thumbs on the interior portions of the eyepiece cup, pressing down and pushing up.
  3. Sony Alpha a7s II Diopter Replacement: 3 단계, 이미지 1/1
    • Slide the eyepiece off by carefully pulling it upward.
    • Be careful not to come into contact with the viewfinder lens as the lens can be easily scratched.
  4. Sony Alpha a7s II Diopter Replacement: 4 단계, 이미지 1/1
    • Remove the screw from the middle of the diopter with the JIS #00 screwdriver.
  5. Sony Alpha a7s II Diopter Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the diopter with your hands. If the diopter is at all stuck you can use the pointed tweezers to help aid in the removal process.
    • Be careful not to let fingers or tweezers come into contact with the viewfinder lens as the lens can be easily scratched.
결론
Jabari Montsho
회원 가입일: 10/24/18
424 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 29
전체 시간: 2,162
