주요 콘텐츠로 건너뛰기
Sony Alpha a7s II LCD Replacement
필요한 것
  1. Sony Alpha a7s II LCD Replacement, LCD: 1 단계, 이미지 1개 중 1개
    • Orient the camera so that the LCD screen is facing you.
  2. Sony Alpha a7s II LCD Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the LCD screen to unscrew the 2 screws on its underside.
  3. Sony Alpha a7s II LCD Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the 2 screws on the bottom of the LCD screen.
  4. Sony Alpha a7s II LCD Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully remove the back of the LCD cover.
  5. Sony Alpha a7s II LCD Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully pull up the LCD front cover from the metal internal frame.
    • Be careful of the wire ribbon as it is fragile.
결론
다른 10명이 해당 안내서를 완성하였습니다.
4가이드 댓글
And the how do you change the LCD screen please ? How to remove it ?
timothee.ferreol - 답글
I have the exact same question, I need to change the screen with flex cable as well. Thanks, there isn’t a lot of info on the a7s 2, it’s all a7r out there
Viro Films - 답글
Hello. My LCD backlight stop working after water came into the camera (snow). With a flash light I was able to determine it is the backlight since I was able to detect some menu items on the screen. I bought a replacement LDC unit, my thinking was that the backlight itself was damaged and a new one would do the trick. After replacing the screen, I have the same probleme. So I suppose my problem come from deeper in the camera. The camera itself do not command the backlight to turn on. Is there something I can do? any more troubleshooting?
Thanks!
Jean-Philippe Archibald - 답글
What size screws!?
Alain Bucio - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 18
지난 30일: 121
전체 시간: 12,955
