주요 콘텐츠로 건너뛰기
Sony Alpha a7s II Tripod Mount Replacement
필요한 것
  1. Sony Alpha a7s II Tripod Mount Replacement, Tripod Mount: 1 단계, 이미지 1/2 Sony Alpha a7s II Tripod Mount Replacement, Tripod Mount: 1 단계, 이미지 2/2
    • Orient your camera so that you are looking at the bottom portion.
    • Using a JIS #00 screwdriver, remove the 7 screws that are securing the metal plate to the bottom of your camera.
    • You do not need to remove that recessed screw that is not connected to the bottom metal plate.
  2. Sony Alpha a7s II Tripod Mount Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove metal plate. Sometimes this plate can become stuck and hard to remove. Use tweezers to separate the plate from the bottom of the camera.
  3. Sony Alpha a7s II Tripod Mount Replacement: 3 단계, 이미지 1/1
    • Flip the plate to the opposite side exposing the aspect that was just inside of the camera.
    • Use the JIS #00 screwdriver to unscrew the the 3 screws surrounding the tripod mount.
  4. Sony Alpha a7s II Tripod Mount Replacement: 4 단계, 이미지 1/1
    • Remove the tripod mount from the metal plate.
결론
Brittany Pourciau
회원 가입일: 10/24/18
304 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 36
전체 시간: 2,718
