소개
This guide is used when a disc gets stuck inside of the disc assembly and the disc tray will not eject. Do not put the disc back in the disc assembly when you complete the guide and follow the disc assembly replacement guide to replace the disc assembly. Make sure that the device is unplugged before starting the guide.
필요한 것
거의 끝나갑니다!
To reassemble your device, follow these instructions in reverse order however do not put the disc back in.
결론
