주요 콘텐츠로 건너뛰기
Sony BDP BX350 Motherboard Replacement
필요한 것
  1. Sony BDP BX350 Motherboard Replacement, Disc Assembly: 1 단계, 이미지 1/1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Motherboard Replacement: 2 단계, 이미지 1/1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Motherboard Replacement: 3 단계, 이미지 1/1
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
  4. Sony BDP BX350 Motherboard Replacement: 4 단계, 이미지 1/1
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
  5. Sony BDP BX350 Motherboard Replacement: 5 단계, 이미지 1/1
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
  6. Sony BDP BX350 Motherboard Replacement: 6 단계, 이미지 1/1
    • Pull the disc assembly out from under the metal tabs on the main casing.
  7. Sony BDP BX350 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove disc assembly.
  8. Sony BDP BX350 Motherboard Replacement, Motherboard: 8 단계, 이미지 1/2 Sony BDP BX350 Motherboard Replacement, Motherboard: 8 단계, 이미지 2/2
    • Do not bend or tear the ribbon cable.
    • Remove all five ribbon cables from the motherboard.
  9. Sony BDP BX350 Motherboard Replacement: 9 단계, 이미지 1/1
    • Unscrew 3mm Philips head HDMI screw from metal casing.
  10. Sony BDP BX350 Motherboard Replacement: 10 단계, 이미지 1/1
    • Unscrew the three 5mm Philips head screws from motherboard.
    • Separate the motherboard from the metal casing by pulling directly up. Use an opening tool if necessary.
결론
Kristen Vezina
회원 가입일: 03/06/17
413 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S8-G5, Catania Spring 2017 UMass Dartmouth, Team S8-G5, Catania Spring 2017 회원
UMASSD-CATANIA-S17S8G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 21
전체 시간: 610
