주요 콘텐츠로 건너뛰기
Sony BDP BX350 Wifi Card Replacement
필요한 것
  1. Sony BDP BX350 Wifi Card Replacement, Control Board: 1 단계, 이미지 1/1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Wifi Card Replacement: 2 단계, 이미지 1/1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Wifi Card Replacement: 3 단계, 이미지 1/1
    • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
  4. Sony BDP BX350 Wifi Card Replacement: 4 단계, 이미지 1/1
    • Remove both covers.
  5. Sony BDP BX350 Wifi Card Replacement: 5 단계, 이미지 1/2 Sony BDP BX350 Wifi Card Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Do not bend or tear the ribbon cable.
    • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
  6. Sony BDP BX350 Wifi Card Replacement: 6 단계, 이미지 1/1
    • Unscrew the one 5mm Phillips head screw from the front of the device board.
  7. Sony BDP BX350 Wifi Card Replacement: 7 단계, 이미지 1/2 Sony BDP BX350 Wifi Card Replacement: 7 단계, 이미지 2/2
    • Do not bend or tear ribbon cable.
    • Carefully separate the device control board from the metal casing.
  8. Sony BDP BX350 Wifi Card Replacement, Wifi Card: 8 단계, 이미지 1/2 Sony BDP BX350 Wifi Card Replacement, Wifi Card: 8 단계, 이미지 2/2
    • Remove 6mm Philips head screw from wifi board.
  9. Sony BDP BX350 Wifi Card Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the ribbon cable from motherboard using a pair of tweezers.
  10. Sony BDP BX350 Wifi Card Replacement: 10 단계, 이미지 1/3 Sony BDP BX350 Wifi Card Replacement: 10 단계, 이미지 2/3 Sony BDP BX350 Wifi Card Replacement: 10 단계, 이미지 3/3
    • Carefully remove board and ribbon cables by pulling upwards then out to free it from the metal clips.
결론
Kristen Vezina
회원 가입일: 03/06/17
413 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S8-G5, Catania Spring 2017 UMass Dartmouth, Team S8-G5, Catania Spring 2017 회원
UMASSD-CATANIA-S17S8G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 264
