소개
In the situation that your Sony BDP-BX510 motherboard is not working, you may need to replace it. This guide will provide you with the steps required to safely remove your motherboard for replacement. The tools that are needed include a Phillips #2 screwdriver, Phillips #1 screwdriver, tweezers, and metal spudger.
필요한 것
Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
거의 끝나갑니다!
결론
