주요 콘텐츠로 건너뛰기
Sony BDP-BX510 Outer Cover Replacement
필요한 것
  1. Sony BDP-BX510 Outer Cover Replacement, Outer Cover: 1 단계, 이미지 1/1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Outer Cover Replacement: 2 단계, 이미지 1/2 Sony BDP-BX510 Outer Cover Replacement: 2 단계, 이미지 2/2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Outer Cover Replacement: 3 단계, 이미지 1/2 Sony BDP-BX510 Outer Cover Replacement: 3 단계, 이미지 2/2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Outer Cover Replacement: 4 단계, 이미지 1/3 Sony BDP-BX510 Outer Cover Replacement: 4 단계, 이미지 2/3 Sony BDP-BX510 Outer Cover Replacement: 4 단계, 이미지 3/3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Outer Cover Replacement: 5 단계, 이미지 1/1
    • Slide the cover forward to remove.
결론
Niki Ngosi
회원 가입일: 01/19/20
375 평판
안내서 3개 작성하였습니다
York University, Team S1-G10, Woodhouse Winter 2020 York University, Team S1-G10, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G10
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 171
