주요 콘텐츠로 건너뛰기
Sony BDP-BX520 Bluetooth Module Replacement
필요한 것
  1. Sony BDP-BX520 Bluetooth Module Replacement, Disc Tray Cover: 1 단계, 이미지 1/1
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Bluetooth Module Replacement: 2 단계, 이미지 1/1
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Bluetooth Module Replacement: 3 단계, 이미지 1/1
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Bluetooth Module Replacement, Top Case: 4 단계, 이미지 1/1
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
  5. Sony BDP-BX520 Bluetooth Module Replacement: 5 단계, 이미지 1/2 Sony BDP-BX520 Bluetooth Module Replacement: 5 단계, 이미지 2/2
    • Gently pull the top case back to remove it from the Blu-Ray player.
  6. Sony BDP-BX520 Bluetooth Module Replacement, Front Panel: 6 단계, 이미지 1/1
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  7. Sony BDP-BX520 Bluetooth Module Replacement: 7 단계, 이미지 1/1
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  8. Sony BDP-BX520 Bluetooth Module Replacement: 8 단계, 이미지 1/1
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  9. Sony BDP-BX520 Bluetooth Module Replacement: 9 단계, 이미지 1/2 Sony BDP-BX520 Bluetooth Module Replacement: 9 단계, 이미지 2/2
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  10. Sony BDP-BX520 Bluetooth Module Replacement, Port Board: 10 단계, 이미지 1/2 Sony BDP-BX520 Bluetooth Module Replacement, Port Board: 10 단계, 이미지 2/2
    • When handling circuit boards like the motherboard and port board, make sure to only touch them on the sides.
    • Locate the large ribbon cable connecting the port board to the motherboard.
    • Detach the cable from the motherboard by carefully pulling upward on the cable.
  11. Sony BDP-BX520 Bluetooth Module Replacement: 11 단계, 이미지 1/1
    • Using the Phillips #2 screwdriver, unscrew the silver, 8mm screw holding the board in place.
  12. Sony BDP-BX520 Bluetooth Module Replacement: 12 단계, 이미지 1/2 Sony BDP-BX520 Bluetooth Module Replacement: 12 단계, 이미지 2/2
    • Using the nylon or metal spudger, carefully unclip the port board from the side of the player.
  13. Sony BDP-BX520 Bluetooth Module Replacement: 13 단계, 이미지 1/1
    • Carefully pull the port board free from the Blu-Ray player.
  14. Sony BDP-BX520 Bluetooth Module Replacement, Bluetooth Module: 14 단계, 이미지 1/2 Sony BDP-BX520 Bluetooth Module Replacement, Bluetooth Module: 14 단계, 이미지 2/2
    • Pull the small 5 pin ribbon cable out of its connector on the motherboard.
  15. Sony BDP-BX520 Bluetooth Module Replacement: 15 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the silver 8 mm screw attaching the Bluetooth module to the front of the case.
  16. Sony BDP-BX520 Bluetooth Module Replacement: 16 단계, 이미지 1/2 Sony BDP-BX520 Bluetooth Module Replacement: 16 단계, 이미지 2/2
    • Remove the Bluetooth module from the case.
    • Make sure to only touch the sides of the Bluetooth module when removing it from the case.
결론
Gregory Pellegrino
회원 가입일: 02/02/15
405 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-41, Amido Winter 2015 Cal Poly, Team 8-41, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G41
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 423
