소개
This guide requires only simple tools, like a screwdriver and metal spudger. Be careful when handling circuit boards to ensure the device does not become further damaged.
필요한 것
Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
Locate the large ribbon cable connecting the port board to the motherboard.
Detach the cable from the motherboard by carefully pulling upward on the cable.
다른 한 분이 해당 안내서를 완성하였습니다.
