주요 콘텐츠로 건너뛰기
Sony BDP-BX620 Disk Drive Replacement
필요한 것
  1. Sony BDP-BX620 Disk Drive Replacement, Outer Cover: 1 단계, 이미지 1/2 Sony BDP-BX620 Disk Drive Replacement, Outer Cover: 1 단계, 이미지 2/2
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
    • Caution, applying too much pressure can break the black covering.
  2. Sony BDP-BX620 Disk Drive Replacement: 2 단계, 이미지 1/2 Sony BDP-BX620 Disk Drive Replacement: 2 단계, 이미지 2/2
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
  3. Sony BDP-BX620 Disk Drive Replacement: 3 단계, 이미지 1/3 Sony BDP-BX620 Disk Drive Replacement: 3 단계, 이미지 2/3 Sony BDP-BX620 Disk Drive Replacement: 3 단계, 이미지 3/3
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
  4. Sony BDP-BX620 Disk Drive Replacement, Disk Drive: 4 단계, 이미지 1/1
    • Remove the no-fuss ribbon cable connectors by gently pulling on them.
    • Pulling harshly may break the flat cables.
  5. Sony BDP-BX620 Disk Drive Replacement: 5 단계, 이미지 1/1
    • Using the Phillips screw driver, remove the three screws.
  6. Sony BDP-BX620 Disk Drive Replacement: 6 단계, 이미지 1/2 Sony BDP-BX620 Disk Drive Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Turn the device over and use tweezers to push the metal clasp until it comes off.
    • Lift the metal brace located over the disk drive and remove the disk drive and the metal brace.
결론
Axel Cruz Jimenez
회원 가입일: 10/05/16
207 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-6, Lacy Fall 2016 USF Tampa, Team 1-6, Lacy Fall 2016 회원
USFT-LACY-F16S1G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 342
