주요 콘텐츠로 건너뛰기
Sony BDP-BX620 Power Module Replacement
필요한 것
  1. Sony BDP-BX620 Power Module Replacement, Outer Cover: 1 단계, 이미지 1/2 Sony BDP-BX620 Power Module Replacement, Outer Cover: 1 단계, 이미지 2/2
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
    • Caution, applying too much pressure can break the black covering.
  2. Sony BDP-BX620 Power Module Replacement: 2 단계, 이미지 1/2 Sony BDP-BX620 Power Module Replacement: 2 단계, 이미지 2/2
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
  3. Sony BDP-BX620 Power Module Replacement: 3 단계, 이미지 1/3 Sony BDP-BX620 Power Module Replacement: 3 단계, 이미지 2/3 Sony BDP-BX620 Power Module Replacement: 3 단계, 이미지 3/3
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
  4. Sony BDP-BX620 Power Module Replacement, Power Module: 4 단계, 이미지 1/1
    • Gently pull on up on the power cord to unlatch it from the metal body of the device.
  5. Sony BDP-BX620 Power Module Replacement: 5 단계, 이미지 1/1
    • Remove the cable connecting the Power Port to the Motherboard by pulling up.
    • It may be difficult to remove. Pull from the plastic part and not the wiring to prevent the wiring from breaking.
  6. Sony BDP-BX620 Power Module Replacement: 6 단계, 이미지 1/1
    • Remove both screws using the Phillips screw driver.
  7. Sony BDP-BX620 Power Module Replacement: 7 단계, 이미지 1/1
    • Lift the Power Module up from the side. See picture.
    • Pull up and away to remove the Power Module
결론
Axel Cruz Jimenez
회원 가입일: 10/05/16
207 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-6, Lacy Fall 2016 USF Tampa, Team 1-6, Lacy Fall 2016 회원
USFT-LACY-F16S1G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 224
